E92 335i 2007 Coupe Boost Control Solenoids
fergusond
Car model: Merc CLK55 AMG
Porsche 993
Post by fergusond » 13 Aug 2017, 10:59
error codes have directed me to a fault on the 'boost control solenoids', which control the turbo waste-gates, took them both off to test, connected voltage and both solenoids click or energize, however you can blow or suck through the ports regardless whether the solenoids are energized or not.
I would have thought the solenoid ports should be closed until energized, as the waste-gate are normally open until closed via vacuum (ie solenoid power to open) to the waste-gate actuators.
Has anyone experience of these solenoids.
cheers
david
Re: E92 335i 2007 Coupe Boost Control Solenoids
Post by M60NJP » 13 Aug 2017, 12:27
Beyond my knowledge, but they could be butterfly valves so are open at both 'ends' of their play?
