BMW 3 Series judders in 2nd gear????
blakeway2513
Car model: BMW 3 Series 320i
Post by blakeway2513 » 13 Jun 2017, 08:11
Hi guys, can anyone offer some advice please?
My car seems to judder in 2nd only under about 2000rpm all the other gears seem to be fine, there are no lights on the dash so I'm lost.
Please help
Mark
Re: BMW 3 Series judders in 2nd gear????
Post by M60NJP » 13 Jun 2017, 08:22
Some car details please???!!!!
Model, engine, transmission etc etc..............
blakeway2513
Post by blakeway2513 » 13 Jun 2017, 12:17
Hi, its an 320 petrol, manual 2007.
Thanks
Post by M60NJP » 13 Jun 2017, 13:28
Another daft comment - under 2000 rpm in a petrol? Are you changing up too soon or too slowly?
blakeway2513
Post by blakeway2513 » 13 Jun 2017, 14:06
Hi, I have had the car for a few years and its only started doing this now. It tends to sometimes judder even if I'm in 2nd over 3000rpm it feels like it loses power for a split second then picks back up.. All the other gears seem fine
Post by M60NJP » 13 Jun 2017, 14:22
Hmm. Assuming everything else does as it should, then it can only be the gearbox. Usually a juddering is a sign of the end of the clutch, but typically it's as abvious in 1st as other gears. The actual gearbox is all mechanical.
For your sanity, I'd take to to you local BMW indepedent and let them test drive it.
tannan
Car model: 2013 bmw 320d f30
Post by tannan » 16 Jun 2017, 21:50
You could sit the car on level ground stop put the car into 3rd lift the clutch slowly and if the car stalls striate away the clutch is not slipping if it tries to set off then the clutch is slipping.
But the shudder could be a warped clutch plate.
