BMW E63 or E64 front dipped beam bulb change - HOW TO
Post by Lewy » 21 May 2012, 18:53
Hi all,
Just thought I'd drop a how to on changing the front dipped beam light bulb as it's not as straight forward as expected:
Firstly you'll need the wheel off as you can only access the dipped beam from inside the arch
Then find the cover' which can be unscrewed using your socket set, note the 2 bolts at the top:
Once the cover is off then unclip the seal:
This will expose the unit which needs to be twisted anticlockwise to remove, note there is a small wire which by doing this is also released:
Then see the part which holds the bulb in place, also turn anticlockwise to remove:
Slide your old bulb out and carefully replace with your new bulb, then reverse the above process:
Put your seal and covers back on and you're away! Job's a good'n! Any problems drop me a PM and I can help you :-bd
Re: BMW E63 or E64 front dipped beam bulb change - HOW TO
Post by M60NJP » 21 May 2012, 19:01
Well done AK_...........?!! =)) =)) =))
Post by Lewy » 21 May 2012, 19:03
M60NJP wrote:Well done AK_...........?!! =)) =)) =))
I'll have you know he was nowhere near (for a change) \:D/ \:D/ \:D/ \:D/ \:D/
Post by Metroreg » 21 May 2012, 19:42
Thats mad to change a light bulb :shock: :shock: , Take the wheel off!!! :lol: :lol:
Post by M60NJP » 21 May 2012, 20:15
:-o :-o :-o :-o :-o :-o and the lights now work???!!!
:@) just flew past
Post by Lewy » 21 May 2012, 23:28
Sadly not as you already know, the ballast is gone, but still, that's how you change the light bulb...
:lol: :lol:
AK_
Car model: '03 E46 M3 SMG vert
'97 E36 M3 Evo saloon - sold
Post by AK_ » 13 Jun 2012, 20:59
Seeing as Lewy is incapable of fixing a simple non working dipped beam I thought I'd have a go......
I switched the ballasts and hey presto the faulty light now works, just got to order a replacement ballast - ebay here we come!
'03 M3 vert
'97 M3 Evo saloon - sold
Being second is to be the first of the ones who lose - Ayrton Senna
Post by Metroreg » 13 Jun 2012, 21:04
My word that's been STRIPPED :shock: Lewy has only left a day =))
Post by RayB » 13 Jun 2012, 21:07
The car looks different for some reason................you've taken the ribbon off :lol:
Good work mate ^:)^ he will be pleased
AK_
Post by AK_ » 13 Jun 2012, 21:13
RayB wrote:Good work mate ^:)^ he will be pleased
Perhaps 'scared' is more likely! =)) =))
'03 M3 vert
