BMW VEHICLE STABILITY / BRAKES WARNING LIGHTS - HELP !
For everything relating to the BMW 1 series
Re: BMW VEHICLE STABILITY / BRAKES WARNING LIGHTS - HELP !
Post by RayB » 08 Jan 2013, 17:20
You could try BMW?? We are in association with Elms BMW here and you'll get 15% off any parts.
You can post your parts request here Elms BMW
Post by M60NJP » 08 Jan 2013, 17:22
Alandoc wrote:Finally get round to taking a wheel off to have a look at the faulty brake wear sensor. Only to find my locking wheel nut thing missing !!! I phoned BMW and they say I can get a replacement for £7 plus vat, which seems unusually reasonable for BMW !!
I had swithered about just going to a garage, but the chap at BMW said if I fit the part propertly the computer should pick up the part and reset the fault light for the brake wear sensor.
Can anyone confirm this? Is there a best place to buy the brake wear sensor to be sure the Car Computer recognises it?
Any advice would be appreciated.
Thanks again - great responses - helpful forum.
Yup the car will detect the replacement sensor. I've always bought mine of E-bay and never had a problem yet- they're a fairly simple electrical contact which completes a circuit when the caliper moves sufficiently towards the disc so there ought not to be anything particular about which one. I've yet to buy one for my 1-series but by 6-series were about £12 from memory.
Post by M60NJP » 08 Jan 2013, 18:19
p.s about £6 on E-bay so if you can get a BMW OEM part for £7 - go for it!
Alandoc
Car model: BMW 1 SERIES - 118 - DIESEL 53 PLATE
Post by Alandoc » 08 May 2013, 20:42
Got some work done at the Garage for the MOT, but the lights are still on (amber) for brake stability. Had a look at the break wear sensor, tried to remove the one that was in place (front offside), but couldn't get it to budge., Any ideas?
Post by M60NJP » 08 May 2013, 20:56
Which end? Disc or connector block?
Silvergrey
Car model: E34 525i Touring
E38 735i
Post by Silvergrey » 13 May 2013, 20:53
Krashbandikoot wrote:
Alandoc wrote:Got some work done at the Garage for the MOT, but the lights are still on (amber) for brake stability. Had a look at the break wear sensor, tried to remove the one that was in place (front offside), but couldn't get it to budge., Any ideas?
Yes
They're embedded into the pads themselves so when you replace the pad you're also replacing the wear sensor, (which is basically just a metal rod with a wire at the end of it), as the warning light is a result of that rod touching the disc to earth it against the car and complete the circuit.
Sure?? (It pains me to question your impeccable electrical credentials :roll: ).
Stratts
Car model: E85 Z4 3.0i Auto
F20 116i 5Door for Mrs Stratts
Post by Stratts » 13 May 2013, 21:20
On E38 and similar you can get the brake sensor warning to go off by just turning the key to II and back three times (provided you have put a new sensor in or just removed the broken one). Having a broken sensor as you called it earlier wont put the light on, it only cones on when the sensor touches the pad.
I'm not convinced the sensor is your problem. You can just take them off and see if you can get the light to go out, no harm in not having them fitted.
2004 Z4 (E85) 3.0i Auto
Member of the number plate police (keep it legal!)
Photographer of people who can't park properly
Stratts
Post by Stratts » 13 May 2013, 21:34
The sensor just unclips from the pad. It's a spade like fitting and just pulls out.
Stratts
Post by Stratts » 13 May 2013, 21:40
No they're the same. The 7 pad sensor just pulls out as well, I did mine a few weeks back.
When you buy new pads they don't come with a sensor, you can use the old one or buy a new one. Same on the E36 which I did last weekend. Have you got a funny variant or are we getting our wires crossed (no pun intended)?
Stratts
Post by Stratts » 13 May 2013, 21:54
Yep, don't recognise the diagram but the picture is right. I have only done E36 and E38 which is the same as the picture of the caliper you posted, on both the sensor just pulls out of the pad. Maybe the 1 series is different.
Return to “BMW 1 Series Forum”
