Turbo
jayjay88
Car model: Bmw E60 530D
Turbo
Post by jayjay88 » 08 Mar 2015, 16:54
Hi guys my turbo went yesturday on my 2009 520d touring is this easy to take off myslef ao i can send it off for reapir
Re: Turbo
Post by M60NJP » 08 Mar 2015, 18:10
Fairly simple, quite a few ancilliaries in the way, but if you have a reasonable degree of knowledge/ability/confidence and an adequate toolkit it shouldn't be a problem.
jayjay88
Re: Turbo
Post by jayjay88 » 11 Mar 2015, 09:53
Thanks i got it off only took half hour new one came yesturday from midlands turbos
richfive
Car model: BMW E61 530D 2004
Re: Turbo
Post by richfive » 22 Jul 2015, 10:31
Don't forget that you will need to clean out the intercooler and all the pipework from the turbo to the inlet manifold, BMW state that the oil supply pipe to the turbo must be renewed (in case it is part blocked I think) and of course you also need to change the oil and filter. If you don't do that - you will find the new turbo will go pop very quickly.
If your car has a DPF you need to check that is not bunged up as well, that could have been a contributing factor in your turbo failing if it is part blocked. There are firms such as DPFGenie that can clean them very effectively.
If in doubt, and when all else fails - read the instructions!!
